Just installed a color control GX on a system that has alternator inputs. When we've done this previously, the ccgx shows a DC charging indicator with input to the batteries when the alternator is charging. This system is not showing that on the display. There is aBMV-712 connected with Ve.Direct and it is reading the charge across the shunt. Is there a configuration bit I need to enable?
