edgargw22 avatar image
edgargw22 asked
BMV-712 Settings; COM port for VE.Bus Charge Disconnect port
What should the BMV-712 relay settings be after I connect the COM port to VE.Bus Charge Disconnect?
The signal from the BMV-712 COM port is OFF when I'm on Shore Power and therefore there's no charging of the house battery. It's also OFF when I don't have Shore Power.
Can anyone point to documentation that talks about settings when I'm using Victron BMV-712, VE.Bus and Battery Protect? The manuals talk about the specifics of each device, but don't provide any assistance when integrating with other components.
TIA
BMV Battery MonitorBattery ProtectVE.Bus
