javiermi avatar image
javiermi asked
multiplus wiring for a sunny boy retrofit installation
I got a sunny boy 2.1Kw tie-grid solar installation with no batteries
I'm considering buying a multiplus 48/3000/50 inverter
I'm trying to reuse the current cabling and switches .
I have been looking at the options, but is not clear how I should connect the output from the current inverter ( sunny boy). Some victron documentation suggest a "hub4" option, so I think this means I will connect the ac output of the sunny boy to the ac output of the multiplus and this will go to the grid - as it is currently wired
Can you confirm this is the right wiring?
Thanks
Multiplus-II
