mbad avatar image
DC charge on Multiplus II 48/3000 GX not working with FW 2.52
I bought a Multiplus II 48/3000 GX 2 months ago.
Everything was working fine with Firmware 2.51 in a way that too much energy produced from external Solar Inverters behind the Multiplus (AC side) have been used to load batteries instead of feeding into the grid.
With Fimrware 2.52 I realized that only PV Power directly connected to the MPPT of the Multiplus is used to charge the batteries and all Energy from other Solar Inverters are feed into the grid although the "setpoint grid" is set to 0 Watt.
My goal is to use the included DC Charger to load batteries as well from external Solar Inverters to charge batteries, e.g. when the weather conditions are bad and the MPPT connected panels are not sufficient to charge my batteries.
That said I downgraded to FW 2.51 again, switched the Multiplus off, waited 2 minutes, switched it on again and everything worked like before.
Seems to be a bug in the 2.52 FW. @Victron team: Who can look into this?
Thanks!
dc systemmultiplus-ii gx
Hi @mbad
I don't see any charging from AC coupled PV at all, but I think this is due to all available energy being used by AC loads, the -2000 grid setpoint, the 2000W inverter limit and the 50A charge current limit you've set.
Best to try with all extra settings to default. I don't see any difference between 2.51/2.52 in the graphs. (yes sunday wasn't very sunny)
Share
Hi @mbad
What is your VRM id?
2 comments Share
@Daniël Boekel (Victron Energy Staff) how should I provide this to you? I guess not here public.
Hi @mbad
No one can do anything with your VRM id, but you can post it more privately by selecting 'viewable by moderators'
