saipro avatar image
saipro asked
Firmware 413 for 48/5000/70 Quattro
@Daniël Boekel
I got a new 48/5000/70 Quattro (230V) yesterday to replace my MultiPlus of similar specs. I want to upgrade the firmware but I'm scared of a bad flash. It has the 413 firmware. Can I get the same firmware sent to me just in case something goes wrong. I want to go the ESS route and have everything ready. It's requesting I have firmware 415 or higher and I have downloaded 433, 459 and 469. Kindly tell me which you think I should flash. I already have the BMV-712, BlueSolar 150/85, CCGX and the necessary peripherals for connectivity.
Thanks
firmware update
Alexandra avatar image
Alexandra answered ·
If you use Victron Connect for the upgrade using the Mk3 the program will select the correct firmware for you and there shouldn't be a problem. Victron usually recommend going to the newest version of firmware.
I have not had any issues with the latest version and running ESS.
https://www.youtube.com/watch?v=Z9VKtoAS8o4
Here is the instruction video for using Connect.
