I am looking into the Victron MultiPlus Inverter Charger 12V/3000VA/120A and want to know what the TR-Charge cable is for?
Thank you in advance
Ahh, ok. Not sure, but I suspect a wire for the 'trickle charge' capability for a separate starter batt on the 12V models.
Hi @Andrew2200
Do you mean this gizmo? https://www.victronenergy.com/accessories/temperature%20sensor%20qua%20pmp%20venus%20gx
It's to allow the Multi's charger to temp-compensate it's charge V's. And in more complex systems to pass it on to other kit as well.
Usually comes in the Multi box, at least for the bigger ones.
Hi John,
The temperature lead is included, but the TR-Charge is not see The quick installation Guide
Item G under not included, any idea?
12 People are following this question.
