windhoos avatar image
windhoos asked
Argo Fet manual diagram vs Victron system diagram examples
I'm redoing my 12V power distribution on my sailboat and one of the items I bought is a Argo Fet 200-2. However, the diagram in the Argo Fet manual is totally different from this example https://www.victronenergy.nl/upload/documents/1.2KVA-12V-MultiPlus-230-Volt-system-example-with-Argo-Fet-and-MPPT.pdf (I mean the Argo Fet part of the example diagram)
I hope that someone can explain the difference to me. Especially why, in the example diagram, Output 1 goes to the starter motor and not directly the starter battery.
Argo FET Diode
6 comments
Hi @Windhoos
the link is not working, can you edit it?
windhoos avatar image windhoos Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
Hi. Strange, the link works in edit mode, but not once published. In any case, I included the link in the question
stavarda avatar image stavarda commented ·
what size cables are you using ? you have drawing of what you are doing ?
windhoos avatar image windhoos stavarda commented ·
stavarda avatar image stavarda windhoos commented ·
@Windhoos Hi Thanks for that , what was the formula for the cable sizes as i see you use 50mm2 for both Starter and house bank?
will be doing a very similar system but using a Victron 12/3000 230 v Inverter charger
My wIndlass is 1200W, So approx 100A. But given startup load and if/when my anchor gets stuck, the current can momentarily be higher. the distance (single cable) is approx 7 meters from the battery to the windlass. This, and the fridge and normal load (pumps, instruments, lights, etc) made me decide to go for 50mm2 cable. I also wanted to have a very small voltage-drop between the alternator-Argo Fet and the 2 battery banks (engine & house). I've used a couple of calculators that I found online. Can't remember the urls, sorry. Just be aware that in most calculators you need to define the total cable run length (Positive and Negative cable lengths)
Hi @Windhoos
That's just how a lot of motors are wired, there is no electrical difference.
