pertussis avatar image
pertussis asked
EasySolar 48/5000 minimum AC input current?
Hi. I'm planning to build tiny house on trailer with solar panels and second hand Nissan Leaf battery modules in 14s14p configuration. EasySolar 48/5000/70-100 MPPT150/100 seems like a great all-in-one solution along with REC BMS.
EasySolar product page or the Victron hosted PDF-files don't specify how low the AC input current can be set. After some searching I'm now aware that the minimum AC input limit varies between different inverter/chargers but the exact information is hidden behind some kind of Victron professional/installer website. Maybe someone here could help me figure out what the minimum AC input current limit is on EasySolar 48/5000/70-100 MPPT150/100.
Also, how big of an undertaking it is to access the backside of Color Control GX in the already assembled EasySolar housing for hooking up the BMS?
Best regards,
Perttu
Venus OSEasySolar All-in-One
wkirby avatar image
wkirby answered ·
The minimum shore current limit for 48/5000/70-100 is 3.9A
The front panel of these devices are secured with four screws at the front, very easy to remove.
