Hi, connection of CCGX to Simrad mfd NSS9 EVO2 does not work. On the Simrad it keeps telling MQTT setting should be adjusted. On the CCGX 2.42 version, there is a different screen wirh two MQTT setting, which one is correct? Pressing home tries to connect, but no result. Cables were tested. Simrad is on latest 18.3 firmware. Should LAN be on? Should start op on VRM be on? Tried all combinations, leds are flickering but no connection. Checked Simrad, rader is working thrue the NEP-2 internet bus on Simrad, Tried direct connection without NEP-2 and different cable, no succes. Tried manual restarting to secure setting, no succes. Any suggestions?
