matt09 avatar image
matt09 asked
Cerbo GX wifi range
Hi - is there any information about the wifi range of the Cerbo GX yet? It looks like a great bit of kit in all other respects.
I'm about to set up an off grid solar system and wonder if I will need to get a usb wifi adapter to get a decent range? (Or Ethernet perhaps - but that will be more complicated)
Does anyone have any experience of it yet in real life situations?
Thanks in advance.
Matt09
cerbo gx
matt09 avatar image
matt09 answered ·
OK - so I've just installed this - an excellent piece of kit.
The wifi is fine: Installed around 10m from a wifi router with stone wall of around 1m between Cerbo and router. Getting 50%-55% signal strength and have been able to update firmware on Cerbo and parameters on a MultiPlus without a problem. About the same signal strength as an iphone or laptop is getting.
Connection to VRM portal is fine also.
Hope this helps anyone else who is interested.
