nicola avatar image
nicola asked
MPPT Smartsolar 75 Load control with older Quattro Inverter
I have recently purchased the Smar tsolar MPPT 75/15 with built in Bluetooth. The app and integration with Smart temperature sensor is excellent.
I would like to use the load output to control an older Quattro 24/8000 that has a remote on/off connection as described here.
Top PCB left side half way up Connector H Quattro remote control Connector for remote switch: Short left and middle terminal to switch “on”. Short right and middle terminal to switch to “charger only”.
Do I need to purchase the # VE.Direct non inverting remote on-off cable Part number ASS030550310.. I was also thinking this could be controlled with a 24v DC relay powered from the load output of the MPPT? Anyone done something similar?
Thanks in advance for any help, Nic
MPPT Controllerssmart solar set-up help
Margreet Leeftink (Victron Energy Staff) avatar image
Margreet Leeftink (Victron Energy Staff) answered ·
It can indeed be done in the way you describe, What the Quattro need is something that makes or breaks a connection, like a switch or a relay.
MPPT Product Page
MPPT Error codes
