John Collier avatar image
BMV-700 not showing me anything correctly
My bmv has been showing me a voltage of -0.01 with 0 amps and doesn’t show when I’m getting solar power. I plug the Bluetooth into my Victron mppt controller and it shows the correct amps coming from the sun and correct volts.
I’m looking for a way to maybe reset my bmv in hopes that will fix it but maybe there’s another solution out there.
I’ve had this bmv for a year and a half no issues btw.
BMV Battery Monitor
Have you checked the fuse? Another possibility is that the data connections is not making good contact.
Hi, sorry to correct, but regular tuning is not how I would describe it.
what the BMV needs is to regularly (automatically!) synchronise. Without regular synchronisations, the BMV SOC parameter will drift.
The video linked by Jaco explains how to (one time) set up those parameters & how the synchronisation mechanism works.
1 comment Share
Further more, this issue doesnt sound like a synchronisation problem.
@John Collier please check your mppt wiring: its battery negative connection must be connected to the load side of the shunt. Not directly to the battery negative. Same for all other chargers & loads: all must be connected to the load side of the shunt.
Only one connection is to be made on the negative terminal of the battery itself, which is the wire to the other side of the shunt.
Anything that bypasses the shunt by being connected directly to the battery negative terminal will not be measured by the BMV.
Jaco Reinecke avatar image
Jaco Reinecke answered ·
A BMV needs regular tuning, like Zeroing it again, synchronizing it when the batts are 100% etc. Just check the manual on how to set both.
Also found this video quite informative:
https://www.youtube.com/watch?v=4ReljfO3k6M
Share
