cavitt avatar image
cavitt asked
Easy Solar Not charging
Hi All, I have got a Easy Solar 24/3000/70 with the MPPT150/70 in it. I installed it just over 3 months ago and it's been working fine. This morning I find that according to the GX Screen the MPPT isn't charging at all (Not showing any power from the PV array and if I go into the settings for the MPPT it says it is "Off") however if I connect via Blue tooth it appears to be working fine. PV Voltage of 84.5v PV Current 14.5A @ 1250w, Battery = 26.55v Current 47.3A bulk Charging.
The GX Screen shows 0w from the PV, Battery voltage of 24.2V -14.2A @ -350w
Any Thoughts?
MPPT Controllersbattery charging
cavitt avatar image cavitt commented ·
I forgot to say that there are no errors showing on the controller...
I would try to reboot the CCGX (pressing the two upper round buttons together) and/or unplug the MPPT and plug it in again.
cavitt avatar image
cavitt answered ·
Thanks M.Lange. The screen reboot did the trick... Any thoughts on why this happened? Should I be worried about it happening again or failing completely?
MPPT Product Page
MPPT Error codes
