abdallah-salamah avatar image
abdallah-salamah asked
one battery bank with different MPPT
Is there a problem to connect MPPT 150/70 and 150/60 to the same battery bank across Dc bus bar ?
chargeroffgrid
Murray van Graan avatar image
Murray van Graan answered ·
Hi @Abdallah Salamah. That should be no problem at all
Justin Cook avatar image
Justin Cook answered ·
@Abdallah Salamah I concur with @Murray van Graan and would simply add that it's important to be certain that you won't be exceeding your battery manufacturer's recommended charge rate at any time; ie, under ideal conditions, with the two controllers named, you could be seeing ~130A of charge into your battery bank, so make sure your bank can safely take that much current at one time.
Victron Offgrid page
