Hi!
Is there a document describing the blow speed / excess current relationship for the different Victron fuse types?
thanks
eliott
@eliott, most MEGA and CNN/CNL fuses in Victron equipment will be Littelfuse OEM; ANL fuses will generally either be Littelfuse or Bussman.
Datasheets here:
You'll also occasionally see a Zeeman ANL
11 People are following this question.
