Warwick Bruce Chapman avatar image
Warwick Bruce Chapman asked
Fuse on Positive Battery Lead - Multiplus II 48v / 3000
The Quick Install Guide for the MultiPlus II suggests a fuse. I carefully cut all my cables throughout the 8-battery array, including the parallel leads and the battery leads the same length.
I did not provide for a fuse.
Should I cut the positive lead to add a fuse?
fuses
wkirby avatar image
wkirby answered ·
It's always a good idea to have a fuse!
Especially good to have one as close to the battery as possible, any faults downstream will then be mitigated by the fuse.
Warwick Bruce Chapman avatar image Warwick Bruce Chapman commented ·
Thank you. When I insert a fuse, should remove a section of the cable as long as the fuse, or is there a more scientific way of measuring to ensure that the two cables (positive and negative) remain equal in resistance (I think)?
sean avatar image sean Warwick Bruce Chapman commented ·
If you are aiming for the technical ideal of matched resistance you'll have to take into account the resistance of the protection device - practicalities of installation usually negates technical ideals. You should be able to find the resistance of the fuse in its specification, that'll allow a best guess calculation as to how much length to remove.
ben avatar image ben ♦ Warwick Bruce Chapman commented ·
There’s no need to match the positive and negative resistances. The idea is to match positives in parallel, and negatives in parallel, as much as possible.
(Separately, it’s a good idea to minimize overall resistance.)
Paul B avatar image
Paul B answered ·
With one multi plus its no big deal to insert the fuse in the cable making the cable longer is no issue,
all that will happen is a very slite extra voltage drop,
ben avatar image
ben answered ·
Maybe use a battery terminal fuse. Those put the fuse as close to the battery as possible (good) and might let you not have to cut your wire.
Thank you. That’s a great idea. Do you have a specific one you prefer using?
I like the Blue Sea ones.
JohnC avatar image
JohnC answered ·
A batt isolator is also useful too. 'Matched resistance' doesn't apply in the case of batt > inverter wires, but between multiple batts to keep them in balance, yes.
Thank you. That is helpful to know.
