I have an all Victron setup, including Lithium, CCGX, Quattro,Lynx ion Shunt, BMV, and MPPTs. The CCGX does not show DC loads. It only shows Grid/Genset, Invert, AC loads, PV, and Battery. Maybe I need a BMS with shunt to show all loads, but I thought the Lynx Ion 1000 shunt would show everything coming in and out of the battery. Maybe I am wrong.
I also read the below setup info in the not so good online manual the last sentence being somewhat surprising.
Rated at 1000 A
Setup
Setup is like setting up a BMV and this is done via the CCGX or VGX.
To find out the meaning of the various settings, please see the BMV manual
Please don’t use the 2-pin terminal block on the Lynx-shunt.
I noticed 2 wires in a snap in block not plugged in. when I plugged it in the ah usage became more accurate, but does not show up as a DC input output on the screen. It shows with in the shunt screen. Unplugging it has the amp hours much less. Plugging it in has it more accurate.
Is there a better schematic for this shunt? How do I get DC info to show on the CCGX?
Thanks,
Jon
