techsol avatar image
techsol asked
Fronius zero feed in - 2 Fronius inverters
I need Your help/advice.
We have client with single phase electric installation.
He has two Fronius inverters. Each inverter has connected 3.6kWp of photovoltaics.
We want to build him ESS on BYD and Multi Plus-II 5kVA.
1st Fronius will be connected to the input of the Multi (when there is no grid – inverter turns off).
2nd Fronius will be coupled on the output of the Multi (when there is no grid – inverter still works).
Client cannot feed Energy back to the grid.
Can we realise zero-feed-in function in configuration mentioned in above (scheme in the attatchment)?
If not can You give me any suggestions?
ESSLithium BatteryFronius
Riaan Barkhuizen avatar image
Riaan Barkhuizen answered ·
Hi @TechSol
Assuming that you have Fronius inverters that are compatible with the Victron equipment I believe that you would be able to get such a system working.
I would have the master fronius connected to the AC-Out and the slave on AC-In. Under the PV inverters menu of the venus device you will be able to tell the venus gx where each inverter is connected. This would improve control during a grid-outage. You would have the ethernet control as well as the frequency shifting control working.
Both grid-tie inverters would have to be setup using the MG50/60 settings with a specific failover for when the one inverter disappears from the system due to a power outage etc.
When the grid is one the venus would be able to control everything nicely.
As far as I'm concerned you have not violated the factor 1 rule, unless both inverters are connected to AC-out.
Let me know how it goes, very interesting setup.
Best Regards
Riaan
techsol avatar image techsol commented ·
Dear Riaan. Thanks for Your suggestions!
Best Regards
laurentiupitran avatar image
laurentiupitran answered ·
here attached you have an 3 phase ESS system configured with ZERO INJECTION in second graph and first graph there is same period of time - one month- where you have used energy from grid and injected energy to grid , even is considered ZERO INJECTION.
Riaan Barkhuizen avatar image Riaan Barkhuizen commented ·
If you want to have absolutely zero feed in you may need to setup ESS to have a minimum consumption of say 100W as a set-point in place of the 0W target.
laurentiupitran avatar image laurentiupitran Riaan Barkhuizen commented ·
hi,
there is not ZERO injection in this kind of regulator in ESS system; in practice, you can set any value that you want as consumption from grid, at the end of experiments you will feed the grid .....
both of pictures are made with 30 w injection in grid; more or less is coming critical as value injected on gird
Dear Laurentin,
thanks for Your answer!
@laurentiu.pitran@gmail.com
