mfortinberry avatar image
mfortinberry asked
EasySolar 48/5000 shore power conversion
I will have the EasySolar 48V/5000kVA on a boat wired for European 230VAC.
When in the US, if plugged into 50A shore power (240VAC/60Hz), will the system effectively convert that to its normal 230V/50Hz output?
Or... do I also need something like a Charles Industries Isolation Transformer installed inline of the shore power?
EasySolar All-in-One
Johannes Boonstra (Victron Energy Staff) avatar image
Johannes Boonstra (Victron Energy Staff) answered ·
You mean you want the 48/5000 Easysolar to be connected on 120Vac/60hz?
Well certainly no Charles industrie products are needed ;-)
When you want an isolated step up/down transformer, please have a look here
https://www.victronenergy.com/upload/documents/Datasheet-Isolation-Transformers-EN.pdf
Whe you want to be also able to hook up to splitphase connections (120/240Vac ) then please have a look here
https://www.victronenergy.com/upload/documents/Datasheet-Autotransformer-32A-and-100A-EN.pdf
Ps in both cases , the input frequency is equal to the output frequency which isnt a problem normally but the Easysolar must be set to this frequency.
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
