alan-norton avatar image
alan-norton asked
How can I set the minimum SOC until the grid fails in an ESS system?
Hi there I have a few weeks old solar system. I have one question: I can change the minimum SOC (unless grid fails) manually. What is the active state of charge? I understand it is a calculation. It used be the same as the minimum SOC? But now it is not?
Confused.
SOC
wkirby avatar image
wkirby answered ·
It depends upon which mode the system is is.
Optimised (without BatteryLife) - will discharge to the minimum SOC and this level is not calculated or raised.
Optimised (with BatteryLife) allows a use settable minimum SOC and then it calculates a rising active SOC limit for each passing day that a good charge is not acheived.
