israel avatar image
israel asked
Monitoring multiple batteries
My system (see picture attached) consists of three batteries: starter, aux1, aux2. The entire system is managed by a system called IBS-DBS. Batteries aux1 and aux2 are isolated from each other by a component called DBR. I consider adding a monitoring system Victron BMV 712.
Question 1 - Is it possible to monitor all three batteries each time one battery (by switching the Victron from one battery to another) in the system that i have?
Question 2 - If the answer to question 1 is positive is it possible to get a scheme about the wiring and switching between batteries of Victron BMV 712 in this particular system for monitoring all three batteries
Thanks, Israel
batterymonitoring
wkirby avatar image
wkirby answered ·
Alas, this will not work.
The BMV calculates SOC by measuring energy into and out of a battery. If it were connected to one battery that is 50% full and then switched to another battery that is 100% full, it would still read 50% because it will not have counted any energy flowing in.
In reality switching batteries would cause the BMV to reset anyway. It is designed to be permanently connected to a battery bank to monitor it.
