lambish avatar image
lambish asked
Orion Tr Negative ouput on ground chassis
Hi, i use 2 Orion Tr in my motorhome and i want to know if i can connect the negative output on the vehicule chassis, because in some case, equipement was energized by orion or vehicule (with a relay to change the power supply of equipement. I don't want to have to many cables.
Thanks
Orion DC-DC Converters not smartGrounding
Hi @Lambish
Yes this is no problem for the dc-dc converter.
lambish avatar image lambish commented ·
So, i've a question about grounding orion output, is it really usefull?
So, if in fault case, a + wire from the orion output Touch the chassis, without a chassis connection between orion negative output and chassis, but between battery (Byd pro) negative and chassis, the fuse will work (fuse on orion output). For me not, but maybe negative input and output is connected...
Ground, earth and electrical safety
