svdauntless avatar image
svdauntless asked
Which inverter/charger to get 220v 60hz OUTPUT ??
Most of my 220v appliances are 60hz. I need aprox 10-12kw of 220 to run cooktop, and oven. Mfg (Miele available in the USA) says appliances run on 60hz and all 220v I see from Victron only output 50hz. Am I missing something? Can I program output to 60hz
AC PV Coupling
wkirby avatar image
wkirby answered ·
Using the configuration software, VE.Configure, it is possible to change the frequency of the inverter to 60Hz.
