Valden avatar image
No preset for charging lead calcium batteries with MultiPlus and SmartSolar MPPT?
Hello all.
I've read the manuals and searched the forum and have concluded that the MultiPlus 12/3000 and SmartSolar MPPT chargers do not have specific presets for charging the lead-calcium batteries my yacht will come with. I haven't had the chance to use these chargers with the Victron Connect app via Bluetooth, but would I be right in thinking it will be a simple job to connect and select desired absorption and float voltages, to suit the batteries?
charging batterycharge controller compatibilitylead-acid
Yes you can adjust the settings to fit the battery specifications.
To connect and setup the multi you will need a MK3 interface.
Share
