Hello all together,
can I use EasySolar 2 with BYD B-Box 5kWh for 1 ph off-grid system.
Thank you for the support!
br
Dima
Hello all together,
br
Dima
Hi @Dmytro Nazarchuk. Yes, you could use it like that. Obviously you would need to set up the Multi and the MPPT inside the EasySolar to correctly charge and discharge the battery, and make sure to use the CanBus interface between the GX and battery.
14 People are following this question.
