When I reboot the CCGX it shows the correct incoming wattage from the MPPT charger, but it never updates the data. Same with the battery voltage. The display shows the wattage/voltage at the reboot time but never updates the info on the display
Configuration: Multiplus 3000
MPPT 150/100 (firmware updated)
CCGX (firmware updated)
BMV712 (firmware updated)
CCGX connected via VE.Direct.cable to the MPPT
