bigal avatar image
bigal asked
VenusOS - vedirect-interface
Does anyone know why the directory
/opt/victronenergy/vedirect-interface/service
Is missing from the installation of Venus OS when installing the Venus OS packages? ( https://github.com/victronenergy/venus/wiki/raspberrypi-install-venus-packages )
Thanks
Al
Venus OS
ers avatar image
ers answered ·
i think that's missing because it wasn't able to be installed..
and i guess if you try to install it like this you'll get this error message:
apt-get install vedirect-interface
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 vedirect-interface : Depends: glibc-deb but it is not installable
                      Depends: libevent-2.0-5 (>= 2.0.21-stable-2+deb8u1) but it is not installable
                      Depends: libevent-pthreads-2.0-5 (>= 2.0.21-stable-2+deb8u1) but it is not installable
E: Unable to correct problems, you have held broken packages.
the main reason is you are not on debian/raspian jessy but a newer os..
looks like there is some work going on here:
https://github.com/jhofstee/meta-bin-deb/issues/2
