rofer avatar image
rofer asked
three solar string monitoring
I have two solar array connected to two Charge controllers (100/35) and linked to the color control GX via two VE direct cables. I want to add a third solar string and use a different sized charge controller (150/45) but there is only two ve direct inputs on the color controller. How do I monitor the the solar inputs?
CCGX Color Control
JohnC avatar image
JohnC answered ·
Hi Rofer. Grab a VE.Direct to USB adaptor: https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
If you run out of usb ports you could use a usb hub too, within limits..
