What is the proper size cable from my shore power inlet to my Multiplus 12/3000/120? Is 6/3 overkill?
@joeyfandel, that's a bit overkill; standard 30A AC wiring would generally call for 10AWG, but the Multi will accept a maximum 6AWG into the AC input screw terminals, so hey, if that's what you have, no harm. Just make sure it's AC-rated wire!
11 People are following this question.
