msleiman avatar image
Smart LFP set points and VE.BMS
What is the correct voltage set point for allow to discharge ? The manual mentions allow to discharge configurable range is 2.6-2.8 V/cell. What is the expected SOC at 2.6 and 2.8V/cell ? What is the reset voltage at which battery reconnects the load ? Also, what is Capacity VS Temperature derating curve for these LFP batteries ? Finally how can I change these set points using VE.BMS ? Thanks.
Lithium battery Smart
Hi @msleiman
Below 3 volt per cell there is really not much SOC left, so best to cutoff loads at 12 volts.
Share
