philip avatar image
philip asked
Smart Solar MPPT 100/20
XI have just purchased a smart solar mppt 100/20 and i have 2 x 100ah lithium batteries with built in bms. The batteries are 12.8 volts . Charge voltage on the batteries is 14.4 volts and cutoff voltage is about 10 volts. My question is can i use the Victron default for LiFePO4 or do i have to change the default settings. The batteries are LiFePO4
MPPT Controllers
wkirby avatar image
wkirby answered ·
Yes, just use the default LiFePO4 setting.
juampa2023 avatar image
juampa2023 answered ·
Hi, is there anything else you need to setup for LiFePO4 non-victron batteries. I´ve heard of disabling ecualization as well. Is that right?
