biozor avatar image
MPPT75/15, use of 5V of Victron VE.direct port as 5V power supply ?
Hello team!
I have a SmartSolar MPPT75/15 and i'm asking if 5V of the Victron VE.direct port could be use to run tiny MCU like Arduino or ESP8266 ? What is the power capability of this pin ?
I know I can use a regulated voltage and current from LOAD output with more components...
Thank you
Matthieu
MPPT ControllersVE.Directarduino
Oh!... And is the Ground pin of Victron VE.direct port same voltage reference as LOAD negative pin ? (VE.Direct GND pin = LOAD negative pin ?) Thanx
Hi @Biozor
Please don't do this, this could give wrong values from MPPT and / or damage it.
it's really a tiny amount it can provide, even using non-standard cables can already give strange error's.
biozor avatar image
biozor answered ·
OK Thanks! 5V Victron VE.direct port is only for voltage level !
So, can I connect GND pin of Victron VE.direct port to LOAD negative port ?
biozor avatar image biozor Daniël Boekel (Victron Energy Staff) ♦♦ ·
hmmm.. yes obviously for voltage level too. And yes, never connect 5V output.
biozor avatar image
biozor answered ·
Hi! I read in VE.Direct Protocol FAQ :
https://www.victronenergy.com/live/vedirect_protocol:faq
"Q5: How much current can I draw from the power pin in the VE.Direct port?
Max 10mA average, with max 20mA/5ms bursts."
Bye!
