stu0468 avatar image
Victron Energy Solar Charge Controller connection to Multi Plus 12/500/20-16 230V VE.Bus
I am trying to build a PV system together with a shore supply in my camper van.Can I connect a
Multi Plus 12/500/20-16 230V VE.Bus to a BlueSolar MPPT 75/15 unit?
MPPT - Solar Charge ControllerMultiplus-II
JohnC avatar image
Hi Stu. Yes you can. But you won't be connecting them to each other, rather just to the same batts. They have no need for a direct connection to each other, and will work independently via Vbat, which both can see.
They may 'interact' by virtue of that Vbat, but that's fine-n-dandy.
Even 2 chargers together, they'll sort it..
Share
