andrewm-za avatar image
andrewm-za asked
50A Buck-Boost converter Pin 1 & 2
Good afternoon all. I stupidly threw away the Pin 1 & 2 connector clip after installing the converters and now want to set up the converter to switch on and off using the ignition wire / pin 1 / purple wire. Does anyone know what clip is required or where I can obtain replacements? Victron don't have any specs on what clip is used so clueless. Thanks very much. Pics of the 2 pins attached1000073822.jpgImage Caption
buckboost
