sbuckley avatar image
sbuckley asked
TSConfig template for a Victron Buck Boot 50-amp DC to DC charger for two 24 Volt battery banks
Please can anybody provide an example TSConfig information template for a Victron Buck Boot 50-amp DC to DC charger for two 24 Volt battery banks one lead acid and the other Lithium Ion Phosphate, this would be very much appreciated.
Current config attached
Visio-SnowHillLady Sterling.pdf
buckboosttsconfig
kevgermany avatar image
kevgermany answered ·
The 50A chargers are only available for 12V systems at present.
sbuckley avatar image sbuckley commented ·
Buck-Boost DC-DC Converter 25A / 50A / 100A - Victron Energy supports 24 Volt
sbuckley answered ·
The 50amp Buck boost DC /DC charger supports 24Volt
It's not a charger, it simply provides fixed voltage output. You can use for fixed voltage charging, but it's not recommended and you have to compromise between overcharging your batteries or a low rate of charge. There's only one 50A charger model, and it's 12V in, 12V out.
