martin-haas avatar image
martin-haas asked
Multiplus: Battery charge fluctuates when feed in
My Setting: 2x Multiplus 5000, 2x MPPT RS450/100, 14.4kWh LiFePO4
With a full battery and while feeding in, the battery charge always fluctuates +/- 1000W instead of simply remaining at 0W:
Otherwise everything looks normal. At first it loads until 100% and 55,2V. After that the Apsorption stays about 54,4V.
Settings: -- DVCC without charging voltage limitation -- ESS: optimized (without BatteryLive) Any idea why the MP is doing this? Thanks!
Multiplus-IImppt rs
