albundy0815 avatar image
albundy0815 asked
Remote console triangle via browser Enter a new one on the device.
today I made a restore to a previous version 3.33 to check a behavior on my side. After the check I updated to 3.34 again.
When I now try to connect via browser (check with MS Edge + Google Chrome). Both are showing me a screen like this attached. Browser cache isn't the issue here. Tested with other clients as well.
When I'm connecting via VRM, the view is ok. I had a look on older issues and all of them are solved via a new version - but right now, there is no newer version available.
Any ideas how to fix that?
Venus OS
home3131 avatar image home3131 commented ·
Same problem over here, didn't touch the software. It just happened this morming
kevgermany avatar image
kevgermany answered ·
I've passed it on to Victron.
4 comments
I have it working again. /var/www/venus/stylingstyles.css was changed to 600. Changed it back to 644 and it's OK again.
Build a new Raspberry Pi4 latest firmware and everything looked OK. After reboot, the same problem occurred
home3131 avatar image home3131 home3131 commented ·
Changed to the beta, but still had the same problem. Locally the remote console is unable, the remote console through VRM works perfectly. I'm lost
Using chrome developers tools I see this
home3131 answered ·
It happens after installing the latest version of GUIMODS
Kevin Windrem avatar image
Kevin Windrem answered ·
Fixed. Update SetupHelper to v8.8 is needed.
For fastest response to issues like this, it's best to post an issue to the GitHub repo for the package. I get email notifications of these and may not see posts on this forum.
When posting here, it is also critical to indicate that you are running third party modifications to your system (GuiMods in this case) so that Victron does not devote resources to investigating a problem that isn't in their code!
albundy0815 avatar image albundy0815 commented ·
Hi, I totally agree, that this should be posted on Github. In my special case, I have installed GUIMods before I've downgraded to 3.33 and later on upgraded to 3.34. So I didn't realize, that my issue was related to GUImods.
I also had a look on it, if there is an update available so far. Next time I'll check that first.
Nevertheless I think it's good to have an entry here in the Victron forum, that also others can see and search for it.
