Hi guys just wondering if my current tank sensor can be used with the cerbo gx or will I need to change the sensor
No way to tell from the pictures. The Cerbo tank inputs are resistance based.
The tank level ports can each be configured to work with either European (0 - 180 Ohm); or US tank senders (240 - 30 Ohm) standards; or to configure a custom Ohm resistance range between 0 Ohm and 300 Ohm (requires firmware v2.80 or higher).
All details can be found in the manual.
41 People are following this question.
