mark-solar-e avatar image
mark-solar-e asked
Multi RS and Smartsolar MPPT Work in Sync
Hi I am new to VICTRON products, so please be very specific in your answer.
I have a MULTI RS 450/100 and have just discovered that is not compatible with Bluetooth Smart Networking. I need to work together in sync with a Victron SmartSolar 450/100 MPPT.
If is not possible via Bluetooth can I daisy chain with CAN BUS ? Do I need a GX? Or I can do it without a GX.
For what I understand so far I could just connect the 2 devices with an Ethernet cable on the CAN PORT and connect an RJ-45 Terminator at the second CAN BUS. Is it correct ?
Multi RS
Alexandra avatar image
Alexandra answered ·
@Mark Solar-E
You can get networked operation when you connect them with CAN as you described and no GX.
How well it works to synchronise i can't say since i didn't care to much about the synchronised operation. Its not really necessary except in one instance, for controlling battery charge current; that should not be a problem if you have a correctly sized battery bank that can take the amps. I did end up buying a GX for the DVCC control for that.
mark-solar-e avatar image mark-solar-e commented ·
I will connect the CAN then , thank you for the confirmation
