barrett avatar image
barrett asked
Phoenix Smart IP43 Charger Smart IP43 Charger Firmware Update Issue
My Phoenix Smart IP 43 Charger recently stopped charging and I had been unable to connect to it via the Victron App.
I took some trouble shooting steps and was able to reset it by disconnecting it, holding down mode, and removing it from my phone's bluetooth. From there, I was able to connect via bluetooth again but I'm immediately asked to update the firmware to v3.50 as it now reports none for the current firmware version.
When I try to update, it stops at 93%. I've exported the log and have attached it here. Can anybody help me spot what the issue might be?
VictronConnect_report.log
Phoenix Smart Charger ip43
barrett answered ·
@Martin (Victron Energy) seems like a similar issue to this one. Any chance you could take a look?
Hi @barrett, the attached service report does not include logs of the actual update. Could you perhaps try to update again and then create a service log without first closing VictronConnect?
And to which other post are you referring? There is no link.
barrett avatar image barrett Martin (Victron Energy) ♦♦ commented ·
Hi @Martin (Victron Energy) thank you for your reply. Please find the updated report log below. I used a hyperlink for the text above but I guess it didn't submit properly.
https://community.victronenergy.com/questions/281858/ip65-charger-24v13a-firmware-325-update-stuck-at-9.html
This report does indeed captured all data of interest. We will investigate and report back asap
