Can you put 2 Phoenix Smart IP43 chargers (12/50-2) in parallel ?
One battery bank with 2 12V 460AH Lifo4 batteries in parallel.
Phill
Phill
Yes, that's possible. You should adapt then the charge profiles of each charger and set up slightly different voltages so that they do not affect each other at the end of the charging process.
26 People are following this question.
