Hi. Is it possible to add a shortcut(button) on the main page of the app(VictronConnect) "status" pane, in order to shutdown the MPPT? More specifically the "charger enabled" button. Or is it planned in a future update?
How often would you need to be accessing the feature to need this as an option? It is usually for maintenance.
Usually a flick of a DC PV breaker works well as well.
The setup is for a cabin. When leaving, the PV system is turned off by this switch or physically unplugging an Anderson connector. So I guess it depends on the users setup. Does not have to be for "maintenance". It is not a big problem by any means. But for older people it would be nice with a quick access to the function in the app.
132 People are following this question.
