I use a MPPT 100/20 and a Liontron 100ah LiFePo Battery and want to know what the correct settings are. Thank you in advance.
@telefonino, you'll need to get the charge profile specs from your battery manufacturer and then cross-reference with the settings of your particular MPPT. In reality, the default settings are usually fine for most LiFePO4 banks, but it depends entirely upon your manufacturer's recommended charge rates/voltages and which MPPT you have, which you didn't specify.
@telefonino: I have Liotron 3x100Ah, 25,8V and a Victron MPPT 150/35 installed.
Did you get detailed information on charge profile from Liontron?
Thanks, Mathias
The datasheet says:
28.8V absorption voltage and CCCV/IU (constant current constant voltage) charging algorithm.
So I would just select the default lithium profile and change the absorption voltage to 28.8V.
Default setting ist he Stop charging at 5ยฐ batterie temperatur ist this conform or i possible i Put die example Stop at 0ยฐ forr the smart mppt 100/30!! Because now start this Period of weather where i am (batterie) really closed to the 5ยฐ Batterie temp!
May you Have pls an Idea!
thnaks a.lot
nice greetings.
14 People are following this question.
