As mentioned in title - does AC-OUT2 with relay assistant become a critical load?
In other words, does it change from a non-essential, to becoming a secondary essential AC-out, like AC-OUT-1?
If you can control that output to do whatever you want, then you can consider that output and connect to it whatever you want - critical or not.
The power used at AC Out 2 is counting to the "critical loads" tile.
Thanks for the replay, but not really what i was asking, so let me rephrase. The AC2 (non-essential), normally disconnects when inverting, prioritizing AC1 (essential). So my question is, when the relay is added to AC2, does it no longer disconnect, acting like another essential out (ie same as AC1)
Using assistants to control the AC OUT 2 relay completely overwrites the default behavior.
41 People are following this question.
