christian500 avatar image
christian500 asked
Multi RS Solar 48/6000
Upgrading my easy solar 1 48/3000
I have a string of 9 panels at 285 7 years old
i have built a 48 volt 400 amp lipo 4 battery
i need to increase my solar panels to maintain battery in winter
at my limit with easy solar so pulling it out and was going to replace with
Multi plus 48 5000 a 450 100 trs and a cerbo and 7 440 watt panels plus distinguished panels
the multi rs 48 3000 was recently suggested as a possible easy cleaner install and cheaper option to achieve my goals
only downside is the panels are higher than 13 amp feed in so would have to source different panels
i am trying to muddle through this obviously a electrician will do install
small off grid shack
thanks in advance
Multi RS
Alexandra avatar image
Alexandra answered ·
@Christian500
13A is the operational input current.
Max ISC IS 16a. What is the isc of your panels?
You can check your config with the mppt online calculator.
christian500 avatar image christian500 commented ·
13.8 isc
13.4 imp
christian500 avatar image christian500 christian500 commented ·
Jinko 440 neo satin 440 watt
Alexandra avatar image Alexandra ♦ christian500 commented ·
So you should be ok. But run it through the online calculator to settle your mind about it.
https://www.victronenergy.com/mppt-calculator
andrii-podanenko avatar image
andrii-podanenko answered ·
No need to change PV. It'll work
I have 580W panels with maximum 16A on my MultiRS. It works just fine.
During winter, when the temperature drops, you'll get more voltage, not current. Which is working good.
