gfaucett53 avatar image
gfaucett53 asked
Li Time Battery
I am using two 200-ah Li Time batteries in parallel with the MultiPlus-II 12/3000/120-50 2 x 120. Li Time says they have a built-in BMS. Do I still need to use a fuse between these and the Multiplus? If so, which fuse would you recommend, and what amperage?
Battery Protectmegafuse
kevgermany avatar image
kevgermany answered ·
Yes add a fuse. Fuse for the cable size and your loads.
pwfarnell avatar image
pwfarnell answered ·
The Multiplus manual has fusing recommendations which are good as long as you use the recommended size and number of cables.
Victron BatteryProtect product page
