Duplicate Items displaying in Device list
The BMV Fw 4.03 and the MPPT Fw 1.43both CCGX FW 2.33
Possible Cause, but I have not been out to the boat to test
I think
VE Direct port 1 was connected to the BMV on the CCGX
VE Direct port 2 was connected to the Smartsolar MPPT
I Then think these may have been swapped over by the customer
so
VE direct port 1 is now smart solar
ve direct port 2 is now BMV
I have had the customer removed both units from the ccgx and tried a full redetect and then also tried a full redetect when they are connected as well.
In the end I still end up with two of each VE direct item
I have not tried a full reset as then all the ccgx VRM setings etc would also be reset and I would no longer have remote access
