arvid avatar image
arvid asked
Victron USB RS485 converter to connect EM530 to PC
I have installed energy meter Carlo Gavazzi EM530 and installed the program UCS-7 (Carlo Gavazzi) on my PC for presentation of measurement data. I want to see the data from the energy meter on my PC before I connect the EM 530 to the Cerbo GX. I have used a 15 m RS485 cable from the meter to the Victron USB RS485 converter which connects to my PC.
The connection has been checked several times
Problem: I have no contact with the meter when I use ModbusRTU and search for the energy meter from USC-7.
The Victron USB RS485 converter only shows a constant red light and no RX or TX signals.
What is wrong?
rs485
Duivert NL avatar image
Duivert NL answered ·
Did you power the meter L1 and N?
11 comments
arvid avatar image arvid commented ·
Power meter EM530 is internally powered, I use EM530 in a 3 phase-3 wiresystem which is common in Norway.
EM530 works OK at the installation place close to the distribution board
Duivert NL avatar image Duivert NL arvid commented ·
Yes ok, but is it powered?
as far as i know and have experience with different cg meters is that they need power to communicate with the software, they are not powered from modbus/rs485
arvid avatar image arvid Duivert NL commented ·
Thanks for answear but on the EM530 there is no way to put more power. I have conected the rs 485 cable to B+, A- and Ground on EM530 according to the installing manual
so the meter is connected to grid?
does the ucs7 software connect with your usb/rs485 interface? (COM),
because the lights on the usb converter should flash even if there is no connection to the meter!
arvid avatar image arvid arvid commented ·
I have tried to measure voltage between B+,A- and Ground and I measure no voltage either AC or DC.
you cant really measure rs 485, its a digital 5v dc signal, check if your software/pc communicates with the usb converter first, looks like thats the problem, could also be a faulty converter
just tested on of mine (original victron) and it flashes with ucs software without meter connected ...
I have now connected my victron usb-rs485 converter without load to my PC. It is connected to Com 4 and gives a constant red light, no flashing
When I look at the Device Manager in Windows 11 it says: This device is working properly.
In the UCS program I select Com 4 and tries the Automatic Connection Search without any result in the USB light
Thats not ok, i suspect its broken…
Thanks for the conclusion Duivert, I will then have to try to advertise to the seller because it was bought in June.
Regards Arvid
