aayman avatar image
aayman asked
Best Configuration to connect smart solar MPPT to SCADA?
What is the best configuration to connect a smart solar MPPT (Starting from 100/30 up to 150/100) to a SCADA network?
  • Use a cable “VE. Direct to USB interface” to connect to smart controller then use USB to Ethernet converter and connect it to nearby network switch?
  • Or should I buy “Color Control GX” and then use cable “VE. Direct to USB interface” to connect to the color control GX then depend on Victron Remote Management (VRM) without the ability to connect to the desired SCADA?
victron communitycommunication protocol
