jvdspoel avatar image
jvdspoel asked
Cerbo Relay
Hi, I would like to use my Cerbo's relay 1 with the Tank pump Menu function. Then I would like to use Relay 2 with the Gen Start stop functionality. Currently I see it is either the one or the other. Can it be done or perhaps are the developers are looking at including this?
Thanking in advance
Relay
jvdspoel avatar image jvdspoel commented ·
Hi, I looked up using Node-red as a option - and that is probably the way in accomplishing with regard to my question. Problem is to get to use and understand Node-Red is not that simple - and for the average user it becomes more of a challenge - But by including the relay 1 and 2 options with the functionality as defined in the current Cerbo's options will make the life of the end users who are not that technically that astute very easy
